Discussion topic: MySky Q box keep dusconnectinĝ
Message posted on 14 Jul 2023 08:03 PM
My sky q box keeps disconecting
Message posted on 14 Jul 2023 08:08 PM
Re: MySky Q box keep dusconnectinĝ
Is this is your main Q box
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 14 Jul 2023 08:09 PM
I do this on a weekly basis - why us it repeatedly disconnecting?
Message posted on 14 Jul 2023 08:12 PM
Maybe the distance is too great @Deborahharria0101
Who is your Broadband supplier?
