Discussion topic: My tv is not working
This message was authored by: momo4
Re: My tv is not working
That doesn't give us a lot to go on @momo4
Some details please including any error messages you're seeing and what you've tried already.
Avatar for momo4
My sky q box has 1 red light on the left and the one on the right is green but my tv seems dead as a dodo
Nothing on the screen whatsoever
Hi @momo4
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Hi @momo4   If the TV is black, is it something simple, like the TV is on the wrong HDMI input?
Can the TV show any other content like freeview or internal streaking apps? Does its menu even come up? Is it switched on?
