4
This discussion topic has been answered Discussion topic: My son sky mini box
This message was authored by: Lylah+mae
My son sky mini box
Hi, my sons mini sky Q box is not working. I've reset it and the red lights come on because nothing was on so I reset it at the back remote control is not working. The only button is letting me press that works is?
Re: My son sky mini box
Hi @Lylah+mae
It's only the Question mark button and the micrphone button which illuminate the remote LED.
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the Q box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Hi @Lylah+mae
This message was authored by: popacatapetal
@oldfella  Are you sure about the remote LED.?
Both my remotes for the main and mini boxes are able flash red with a long press on the power button to turn off the box and tv simultaneously.
I have only recently noticed this so might be something to do with the recent update to Q250
Doesn't happen with my remote here @popacatapetal
edit
Also on the latest software here
Avatar for Lylah+mae
Nope that did not work
