Discussion topic: My smart tv is suddenly saying we are not connected to internet after years of being connected. h!
This message was authored by: Jennyp3
We have tried all the troubleshooting and it still is not connected to the internet. All other devices in the house are ok and connrcted. Is this snything to do with the weekends outage probkems?
Re: My smart tv is suddenly saying we are not connected to internet after years of being connected.
Hi @Jennyp3
hi @Jennyp3
Is this your Smart TV itself rather than the SKY box ?
If so, even though other devices are working, please may I suggest you  try a full power down restart (i.e. switch off at mains or unplug) of your router followed by your TV.
Avatar for Jennyp3
Thank you all for your replies - I have been pressing the reset button instead of the wps  button but have since located the right button and it has now reconnected. Many thanks for taking the time to help 😊
