Discussion topic: My sky q remote control
Message posted on 18 Aug 2026 01:50 PM
Two of my sky Q mini box remote controls are not working. we have changed the batteries only certain buttons are working! how do I go about getting two replacements?
Message posted on 18 Aug 2026 02:47 PM
Re: My sky q remote control
Hi @Simo1976 They are available is most large stores or on-line stores like Amazon. You can test if the remote is working but not paired to your Sky Q box by pressing "?", the LED should light up. The odds against two remotes that stop working, must be a million to one. Try holding down 4 & 6 to turn off Bluetooth, and then point direct at the box (line of sight).
Message posted on 18 Aug 2026 03:04 PM
Thank you. I'll give that's a try 👍🏻
