Discussion topic: My sky q box won' connect to my sky bbrodband.i ave tried resetting both the sky q box and the route
This message was authored by: Burnzybhoy12454
I can't get my sky q box to connect to my sky broadband I have tried resetting both the sky q box and the router but still won't connect
Re: My sky q box won' connect to my sky bbrodband.i ave tried resetting both the sky q box and the r
Hi @Burnzybhoy12454
You need to carry out a Network reset on your Q box (not just a reset)
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Sky broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Avatar for Burnzybhoy12454
Thanks for the reply but I can't find the option for the network reset I have tried to add a vid
eo to show you
Yes OK @Burnzybhoy12454
That is a similar option .
You need to choose connect to Sky Broadband WiFi
You will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Yes matr I have tried that option a few times now and followed the instructions presses the WPS button on the router till it flashes orange but always fails to connect I've tried unplugging both box and router for 10 mins but still won't connect phones and laptops all connecting no problem
Looks like it's a call to Sky @Burnzybhoy12454
You may need a Q WiFi booster to position midway between the mainQ box and the router
Yes think I'll need to call them again see if I can get through to anybody 🤣 thank for your time mate
