Discussion topic: My sky q box keeps going into standby every 30 seconds
This message was authored by drewotley This message was authored by: drewotley
My sky q box keeps going into standby mode after 30 seconds or so, then randomly restarts to then shut down again
I am not getting any pictures on the screen but do get audio when it turns on again
So far I have tried unpluging all the cabels, turning the box box off and unpluging from the wall, I have disconnected the mini box and the box is cool to the touch so not over heating.
Any suggestions?
Re: My sky q box keeps going into standby every 30 seconds
Any suggestions?
Hi @drewotley
This message was authored by Chodley This message was authored by: Chodley
Does the power light change colour when this happens?
