Discussion topic: My sky multiroom is intermittent
Message posted on 14 Jul 2023 03:24 PM
Hi, my sky box in the kitchen has been having ongoing issues. It keeps freezing, and when I try and forward it rewind a program it is slow to respond and doesn't always work
Message posted on 14 Jul 2023 03:27 PM
Re: My sky multiroom is intermittent
Hi @target484
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Failing this you probably need a Q WiFi booster to position midway between the main box and the mini.
Message posted on 14 Jul 2023 03:32 PM - last edited: 14 Jul 2023 03:36 PM
@oldfella wrote:
Hi @target484
Particularly as the Mini is in a room which tends to have 'noisy' electrical equipment (microwave, fridge, freezer, toaster, kettle etc) intermittently generating a nice burst of EMF interference.
In particular you really don't want a microwave in between your router and the Mini: they contain both a signal generator and signal shielding.
