Discussion topic: My sky box is not working!!
This message was authored by: Bilyana1
I pressed all the buttons and turned box on/off and still nothing!
Re: My sky box is not working!!
@Bilyana1
Any lights showing on the front of the box? Any error messages on screen?
Hi @Bilyana1
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
