Discussion topic: My sky box is not responding
This message was authored by: jojohnson6
My sky box is not responding to con trolls and new batteries are in
Re: My sky box is not responding
Hi @jojohnson6
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
