Discussion topic: My sky Q box regularly doesn’t communicate with other boxes
This message was authored by: BossPit
I can't download any programs. Message comes up saying it is a technical issue
Re: My sky Q box regularly doesn’t communicate with other boxes
hi @BossPit
If this is a mini box
Reboot the mini as above.
