Discussion topic: My mini box not workng
This message was authored by: Dailey
My mini box somehow not working I tried everything and just don't know what else to do.
Re: My mini box not workng
@Dailey Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Dailey
I've done all that and still not connected, it has been like that for 3 days now.
Hi @Dailey
Try a Network Reset on the mini.
You will be asked to press the WPS button on the main Q box (not the mini as the Netwoek reset will start the mini WPS automatically ).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
