Discussion topic: My mini box is not working
This message was authored by: Parm3
My Mini Box is not turning on at all.
Re: My mini box is not working
Hi @Parm3   Is that with both the remote and the on/off button on the box?
Avatar for Parm3
Yes
Avatar for Parm3
It has the red/orange light but not turning on
Avatar for Parm3
It was absolutely fine this morning.
i have two accounts and I cancelled one mini box from my other account. I am hope they have not cancelled this one instead of my other property?!!!
Hi @Parm3
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the Q box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for Parm3
Thank you it's all working now.
