Discussion topic: My mini box is not picking up any stations
Message posted on 12 Apr 2024 07:40 PM
Mini box is not picking up stations error message is
check your subscription entitles you to view this channel on this box otherwise if using box for first time wait a few minutes
this stopped working last night
Message posted on 12 Apr 2024 07:43 PM - last edited: 12 Apr 2024 07:45 PM
Re: My mini box is not picking up any stations
Hi @Gill98
Reboot the mini as above.
If the mini still does not connect correctly try a Network Reset on the mini.
If you still have the same issue try a Reset Settings in the Main Q box hidden menu.
Message posted on 14 Jun 2024 04:20 PM
will i lose my recordings?
