Discussion topic: My main box tv works fine but tv using the mini box keeps freezing
Message posted on 24 Aug 2023 10:50 AM
Sometimes it works but maybe for a few minutes only then it freezes
Message posted on 24 Aug 2023 10:59 AM
Re: My main box tv works fine but tv using the mini box keeps freezing
Hi @Mark
Try the following;-
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Failing all this you may need a Q WiFi booster to position midway between the main Q box and the mini.
