Discussion topic: My main box keeps freezing
Message posted on 12 Dec 2023 07:29 PM
My sky box freezes at least every other day, we've tried letting it sit for long periods of time to see if it comes good but only way is to turn it off and back on again at plug
Message posted on 12 Dec 2023 07:55 PM
Re: My main box keeps freezing
Hi @hetty2013
See if a Reset settings helps.
Reset Settings in the Q box hidden menu.
