Discussion topic: My apps not working
This message was authored by: Sarb19
My apps not working
I cannot get Netflix and other apps as not connecting to broadband
Re: My apps not working
Hi @Sarb19
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
