Discussion topic: My Sky Q mini boxes have stopped working
This message was authored by: gnasher1966
both mini boxes say Program unavailable even though I have had multiroom for over 10 years use them daily.
Re: My Sky Q mini boxes have stopped working
Hi @gnasher1966
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Failing all this
Try a Reset Settings in the main Q box hidden menu.
