Discussion topic: My Netflix will not load
This message was authored by Mickey1 This message was authored by: Mickey1
what can I do ?
this has happened before
customer services could not help
Re: My Netflix will not load
what can I do ?
Hi @Mickey1
If you haven't already try a Reset Settings in the Q box hidden menu.
