This discussion topic has been answered Discussion topic: Multiscreen
Message posted on 22 Apr 2025 07:10 PM
Do you get 2 miniboxes if you subscribe to multibox?
Message posted on 22 Apr 2025 07:13 PM
You need a Multiscreen subscription to order a mini box (or more).
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
