1
This discussion topic has been answered Discussion topic: Multiscreen box won’t let me watch programmes
This message was authored by: Karen654
When I am trying to watch either the tv or any recordings on my multiscreen box it displays the following message. I am able to watch all the channels and recordings on my main box.
"Please check your subscription entitles you to view this channel on this box. Otherwise if you're using this box for the first time, please wait a few minutes."
Thank you
Re: Multiscreen box won’t let me watch programmes
Thank you
H @Karen654
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Thank you
H @Karen654
