Discussion topic: Multiroom
Message posted on 07 Dec 2024 02:31 PM
Multiroom
Our multiroom box isn't working
Message posted on 07 Dec 2024 02:40 PM
Re: Multiroom
What's happening with your Sky Q mini.
Is it not turning on or are you getting an error message
Message posted on 07 Dec 2024 03:32 PM
Re: Multiroom
Hi @Yasmin1996
Reboot the mini as above.
