Discussion topic: Multiroom
This message was authored by: Wellzy
Multiroom
2 multi room boxes upstairs in the house, both of which the picture continually freezes
Re: Multiroom
@Wellzy Have you tried rebooting your main Q box ie
then
reboot your mini boxes
Re: Multiroom
Hi @Wellzy
try Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
