Discussion topic: Multiroom box keeps saying does not support hdcp changed cable,input even tv,done reboot etc etc,any
Message posted on 22 Mar 2023 04:25 PM
Sky mutiroom box keeps getting blue screen with a load of writing saying does not support hdcp and try another cable or input,done both and even bought new tv,done reset and reboot now gets blank screen as if turned off,you go to turn off box and the picture appears then goes off,switch the box back on and no picture,is the box faulty
Message posted on 22 Mar 2023 05:08 PM
Re: Multiroom box keeps saying does not support hdcp changed cable,input even tv,done reboot etc etc
@Gazza1995 do you jst have the one multiroom box or do you have any others. If you have more than one can you swap the faulty one with one that works and see if you get the same problem ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 22 Mar 2023 05:19 PM
Hi @Gazza1995
With the mini box on with Green Led try pressing the following on the mini remote.
Home 1 0 8 0 Home
This will set the mini to standard 1080i resolution. This may be more amenable to the HDCP issue.
