Discussion topic: Multiroom box keeps glitching
Message posted on 09 Oct 2023 05:59 PM
Hi all, my multiroom box keeps pausing like it's downloading content.
This happens regardless if I'm watching live tv, or a recorded program.
It doesn't happen if watching Netflix or Amazon video though, so internet must be ok?
Message posted on 09 Oct 2023 06:05 PM
Re: Multiroom box keeps glitching
@Mikeal1 Have you tried rebooting your main Q box ie
then
reboot your mini box
Message posted on 09 Oct 2023 06:10 PM
I have restarted the main box, the router and the multiroom box. All to no avail.
Message posted on 09 Oct 2023 06:23 PM
have a Network reset
you can do this by going into
Home > Settings > Setup > Network on the mini box
Highlight Status and then select Reset.
You should be asked to press the WPS button on the nearest piece of Sky Q equipment so main box router or another mini the WPS will automatically start flashing on the mini box you are resetting the network on
