Discussion topic: Multiroom box discovery plus app not showing
This message was authored by: TessN22
I have Multiroom discovery works fine on main box but app does not show on the second box how do I fix this ?
Re: Multiroom box discovery plus app not showing
@TessN22 you could try refreshing the apps in the engineers menu on the mini box
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
this can take upto 24 hours to work but is normally less
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
