Discussion topic: Multi room with sky q , does this need to be wired in ? Does it require an engineer visits
Message posted on 16 Aug 2023 07:46 PM
Do you require cables for mutli room ? Do you require a engineers visit. Thinking off getting installed but don't want cables or more holes in walls thanks in advance
Message posted on 16 Aug 2023 07:52 PM
Re: Multi room with sky q , does this need to be wired in ? Does it require an engineer visits
Hi @SUESUE0406
Normally Sky Q mini boxes are connected by WiFi to the main Q box.
They still need a Power lead and HDMI cable to TV.
Also bear in Mind that to use mini boxes you need the monthly Q Multiscreen subscription.
Doesn't need any extra holes in walls but maybe best if installed by Engineer as WiFi can be unpredictable.
Message posted on 16 Aug 2023 07:57 PM
Thanks it wasn't so much an engineer happy to have an engineer visit just not more holes etc thanks very much
