2
This discussion topic has been answered Discussion topic: Mrs Angela
This message was authored by: AngelaCopland18
Mrs Angela
Accessibility on Sky q mini box is stuck on the screen and cannot go any further
Re: Mrs Angela
@AngelaCopland18
Sky have previously suggested the following...
  • Unpair their Sky Q remote from the box by holding 4&6
  • Wait for the remote to flash
  • Then dismiss the information screen "Skip & set up later"
  • Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Re: Mrs Angela
@AngelaCopland18
Re: Mrs Angela
reply deleted as @Daniel0210  posted similar
