Discussion topic: Moving to a conservation area
Message posted on 24 May 2025 09:03 AM
I am currently tied into a contract till 2027. In the coming weeks, I will be moving home.
the area in which I am moving too, is classed as a conservation area, after a lot of questions and a lot of waiting the local council have confirmed they will not give planning permission to install a sky satellite dish. Which leaves me with an obvious issue.
has anyone encountered this?
Message posted on 24 May 2025 09:10 AM
Re: Moving to a conservation area
Move to stream if the broadband is up to it?
Message posted on 24 May 2025 09:11 AM
Will sky allow that? I can't find any option for stream on my sky account that's why I asked.
Message posted on 24 May 2025 09:13 AM
You'll have to call. The alternative is to pay for a service you can't use. (Unless Sky are prepared to release you from the contract)
Message posted on 24 May 2025 10:19 AM
@BoodleO92 wrote:Will sky allow that? I can't find any option for stream on my sky account that's why I asked.
Sky are actively encouraging customers to switch to streaming services, you just need to phone to do it.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 24 May 2025 10:40 AM - last edited: 24 May 2025 10:42 AM
As above, if you currently have Sky Q, you will have to call Sky to move to Sky Stream/Glass from Sky Q.
The key to Sky Stream/Glass is having a good broadband connection.
Not just broadband speed to your house and router, but for your local network supply via wifi or ethernet, that can be affected in a busy household.
The Sky recommended minimum broadband speed is 25Mbps.
Or 30Mbps if you add an extra Sky Stream puck or watch in UHD.
Have a read of the Sky Stream FAQ, that gives a good overview of how it all works and plays out for a subscriber.
https://www.sky.com/help/home/sky-tv/sky-tv-stream/sky-stream-faqs/articles/sky-stream-faqs
Message posted on 24 May 2025 11:23 AM - last edited: 24 May 2025 11:42 AM
@BoodleO92 If you would prefer to continue to have Sky Q, and your new property has a garden, then it might well be worth asking a suitably qualified independent local engineer to check if there is a position where you could receive satellite transponder signals using a satellite dish mounted on a short pole in your garden.
An example of a typical pole mounted dish;
Godfrey.
