Discussion topic: Moving sky wire
This message was authored by: Brad33
Moving sky wire
We have recently moved our new TV to a different position in our lounge and the exsisting sky cable does not reach the TV and the Sky Q box needs relocating with a few feet
.Also our Sky Wi fi box cable is not long enough and is on the floor which affects the signal the wiring needs extra length
Re: Moving sky wire
You can buy extension cables of different lengths for both the dish cables and the phone cable.
If you want the entry point for the dish cables moved, Sky will do that for you, at a cost, I believe, of £65.
Similarly if you want the location of your master phone socket moved, Sky should be able to do that for you for a further £65.
