Discussion topic: Moving my TV point
Message posted on 14 Sep 2026 06:02 PM
Moving my TV point
Hi All
When the engineer installed my sky following a house move, it was installed in the corner of the lounge closest to where the connection came into the house. Unfortunately the engineer didn't give us a lot of wiggle room on cables. I'm now wanting to move everything - TV/router - across the room to the opposite side. Will Sky come out and fix the short cable or is it something i can sort out myself?
Thanks!
Message posted on 14 Sep 2026 06:05 PM
Re: Moving my TV point
@MartineG You can purchase Satellite cable extension kits for a few ££s to fit yourself.
Message posted on 15 Sep 2026 07:51 AM
Note that relocating a router is a different operation to moving a satellite television box.
