Discussion topic: Move q box to bed room
This message was authored by: Antony55
No sky signal on my upstairs cables when I move Q main box to bedroom
Re: Move q box to bed room
hi @Antony55
SKY Q uses twin cables with a 'Wideband' feed
The cables to your bedroom would either be disconnected or if you had arranged it with SKY  to older 'Universal' outputs on what is called a Hybrid LNB.
SKY Q cannot work with Universal outputs
If you need it moving permanently you could arrange for the wideband outputs to be switched over at the dish (actually the LNB - the electronic bit n the dish)
