Discussion topic: Missing
Message posted on 13 Jul 2023 05:13 PM
Missing
Hello, my sky box arrived but only have one? The broadband was fitted, went to set up tv and noticed I only have one when I've paid for 2..... also I've had nothing from The refer a friend scheme? I applied online. Heard nothing
Message posted on 13 Jul 2023 05:29 PM
Re: Missing
@Lexi+loo wrote:Hello, my sky box arrived but only have one? The broadband was fitted, went to set up tv and noticed I only have one when I've paid for 2..... also I've had nothing from The refer a friend scheme? I applied online. Heard nothing
What exactly did you sign up for? Sky Q with multiscreen and Sky Broadband?
The broadband hub is delivered direct to you for self-install, but the Sky Q boxes will be brought by an engineer who will also fit a dish and cabling if you don't already have it.
