Discussion topic: Missing bbc channels
This message was authored by: Rosemary19
I had a new skyQ box installed last Friday.
All good except bbc news 24  and bbc parliament channels do not work
Re: Missing bbc channels
You'll need to provide more info as "do not work" tells the forum nothing about your issue.
@Rosemary19 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Rosemary19
Thank you for your replies. I tried disconnecting everything but this did not fix the problem.
in addition, I now find channel 5 is also missing.
The screen is blue and across the top it says
This channel is currently affected by a problem with your satellite signal. For help press?
I have tried this but it doesn't solve the problem.
Do you have your own dish or communal?
Thank you,
I have my own dish. This problem started when the sky Q box was installed, he did change something on the dish.
