Discussion topic: Missing apps from sky q mini box
This message was authored by: Spaton85
Good evening.
I have moved my sky q mini box into a different room. It is working fine, but it will not display any of my apps. I have tried rebooting system still no apps. Please help
Re: Missing apps from sky q mini box
@Spaton85 wrote:
Good evening.
Hi @Spaton85
All Q boxes including minis should be on the same software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software.
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
If/once all boxes are on the latest software version
Try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
