Discussion topic: Minibox
Message posted on 14 Jun 2025 10:54 AM
Minibox
Message posted on 14 Jun 2025 12:54 PM
Re: Minibox
@weezel wrote:
I've had a minibox for ages and could never get it working....gave now got sky broadband and I still can't connect and if it does the main box closed connection to the sky hub....any ideas
Hi @weezel
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
