Discussion topic: Minibox won't connect
Message posted on 09 Oct 2023 06:02 PM
My mini box will not connect
Message posted on 09 Oct 2023 06:06 PM
Re: Minibox won't connect
@Martyn13 Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 09 Oct 2023 06:11 PM
hi @Martyn13
If the reboot suggested by @Laing1 doesn't work you need to carry out a Network reset on the mini
