3
This discussion topic has been answered Discussion topic: Minibox is dead
This message was authored by: CAstbury
Minibox is dead
One of our miniboxes isnt working. Have tried switching it off, it says its setting up, tells me to press home when screen goes blank. Then it just says "no signal"
It's dead!
Other minibox is fine.
Avatar for CAstbury
This message was authored by: CAstbury Answer
Re: Minibox is dead
Sky have sent a new minibox. Credit to Sky, new box arrived 17 hours after advising them of problem. Very impressed.
Re: Minibox is dead
It's dead!
Hi @CAstbury
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for CAstbury
Re: Minibox is dead
Thanks for reply. Tried that and got screen saying screen 1 of 4 but  nothing else. Just stuck on that screen.
Avatar for CAstbury
Re: Minibox is dead
