Discussion topic: Mini sky box not working
This message was authored by: Margaretkenned
My  sky box in Kitchen is not working but the one in my lounge is working- what could the problem be please??
Re: Mini sky box not working
Hi @Margaretkenned
Reboot the mini as above.
