Discussion topic: Mini sky bos not turning on and when it does it stops again
This message was authored by: beene1967
the sky mini box I got sent no longer turns on.
The main rooter has problem too, the light indicates I'm not connected that light is off
Re: Mini sky bos not turning on and when it does it stops again
Hi @beene1967
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the Q box on with green led try completly resetting yourmininBluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Regarding your router try resetting
