Discussion topic: Mini q
Message posted on 31 May 2026 03:48 PM
Mini q
Maximum number of sky q mini boxes already use
Message posted on 31 May 2026 03:53 PM - last edited: 31 May 2026 03:54 PM
Re: Mini q
@Holly5- wrote:Maximum number of sky q mini boxes already use
Hi @Holly5- That appears to be a statement and not a question? With Sky Q Main boxes with a hardware version of 32Cxxx only one Mini box can be used for live and recorded TV at the same time. If it is 32Bxxx then it is two. Up to 4 Mini boxes can be connected on all boxes.
Message posted on 31 May 2026 03:55 PM
Re: Mini q
@Holly5-
Sky will loan you a maximum of 4 mini boxes. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Disney+. That limit does not change if the main Sky Q box is not being viewed. Remember that UHD content can’t be viewed on a mini box.
The original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one monthly Multiscreen subscription.
