Discussion topic: Mini hub not working error NR 102
This message was authored by: Kitchen+Envy
Mini hub keeps stopping. We reboot and it works for a short while, sometimes half hour but sometimes only a few minutes. Says errror 102
Re: Mini hub not working error NR 102
That's a WiFi connectivity issue.
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Make sure that you press the WPS button on the router and not the reset button.
