Discussion topic: Mini boxes
Message posted on 19 May 2025 08:33 PM
Mini boxes
I just bought another mini box but I can only use one at a time? This is no use to me and I need to add another mini box next month (will have three in total) but only being able to use one at a time is pointless! How do I change this?
Message posted on 19 May 2025 08:45 PM
Re: Mini boxes
You didn't buy it. It was loaned to you.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
