4
This discussion topic has been answered Discussion topic: Mini boxes won’t work
This message was authored by: Vxt
All Mini boxes screen is blank black or blue. Main box works, we have deleted recordings below 40% and reset settings in settings menu but no mini box working now? Please help!
Re: Mini boxes won’t work
@Vxt wrote:
Thank you, I now have an issue, as I went in to status on settings and clicked reactivate on watch on sky Q mini box, now nothing works!? Not even main box, main box screen now's says technical fault?
Hi @Vxt
Have you tried rebooting your main Q box?
Hi @Vxt
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Avatar for Vxt
Hi @Vxt
Avatar for Vxt
This has worked. Thank you very much for your help 👍🏼
