Discussion topic: Mini boxes won’t connect to main box or broadband
Message posted on 27 Nov 2025 08:36 PM
Ok I've had this problem for a few days now, both mini boxes can't connect to the main box or broadband. I've tried switch all boxes off and on, I've reset the boxes and reset the broadband but they still won't connect. I'm getting really frustrated now as this is becoming a regular problem. I'm paying nearly £100 a month and having this happen nearly 8 times a month is getting ridiculous.
Message posted on 27 Nov 2025 08:40 PM
Re: Mini boxes won’t connect to main box or broadband
Hi @Rosemary4
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max)) if on Sky Broadband or previously connected mini).
