Discussion topic: Mini boxes not working
This message was authored by: Sharon411
The 2 sky mini boxes are stating they are not connected to the main box even after rebooting the main sky box and wifi
Re: Mini boxes not working
Hi @Sharon411
I know you said that you have rebooted but try the following procedure.
Reboot the mini as above.  Start with the mini nearest to the main Q box.
As you are on Sky Broadband if the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.  Follow the same procedure for other mini.
