Discussion topic: Mini boxes not working
Message posted on 16 Mar 2024 10:14 PM
I have 2 sky q mini boxes that have no channels any suggestions
Message posted on 16 Mar 2024 10:26 PM
Re: Mini boxes not working
Hi @Andrew19682
Reboot the mini as above. Start with the mini nearest to the main Q box.
As you are on Sky Broadband if the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box. Follow the same procedure for other mini.
Message posted on 16 Mar 2024 11:19 PM
2 of my sky q mini boxes are not working, saying programs unavailable to check subscriptions. I've done all the rebooting, unplugging, reactivating etc and still not working. What does it mean to check subscriptions, when I have the full sky Package
