Discussion topic: Mini box
Message posted on 25 Jul 2026 12:15 PM
Mini box
Mini box will not connect to main Sky box or network. Have unplugged tv & mini box. Have unplugged router. Still no connection. Error code MR102
Message posted on 25 Jul 2026 12:23 PM
Re: Mini box
@HoB2 wrote:
Error code MR102
@HoB2
It’s always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Also see this link here
https://helpforum.sky.com/t5/Sky-TV/Error-Codes-on-Sky-O-and-Glass/ba-p/4017045
