Discussion topic: Mini box
This message was authored by: Nic+Ben
Mini box
We had a new main box fitted but since then all mini boxes loose connection in the evening but we can still use the apps so not an internet problem
Re: Mini box
Hi @Nic+Ben
Reboot the minis as above.
If the minis still do not connect try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
