Discussion topic: Mini box
Message posted on 27 Nov 2025 11:34 AM
Mini box
I would like to add another mini box to my ststem
Message posted on 27 Nov 2025 11:42 AM
Re: Mini box
You'll need to call Sky. They are likely to charge £50 admin for the box to be loaned to you.
As it seems you already have a multiscreen subscription there will be no other charges.
However, the number of concurrent mini's is limited to 2 (1 on some old boxes).
Message posted on 27 Nov 2025 01:18 PM - last edited: 27 Nov 2025 01:20 PM
Re: Mini box
Hi @Steve3010
As indicated by @PandJ2020 not all Q boxes allow simultaneous use of more than one mini.
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box (32Cxxx) only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
Subject to the above limits Sky Q minis can be used completely independently of the main Q box and the same or different program or recording can be viewed on each Q box. Even if viewing the same content it is completely independent and can be viewed at the same or different point.
Minis can do all the features same as the main Q box and can set or delete recordings on the main Q box hard drive. There is one single storage area on the main Q box with no profiles and no indication of which Q box has set a recording. (Unlike Sky+HD Multiroom which has independent storage and planners).
It should also be remembered that minis cannot set or view UHD recordings or content.
